Introdução
Following these steps, you can effectively replace your display.
Peças
Nenhum componente especificado.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
2 outras pessoas concluíram este guia.
