Ir para o conteúdo principal
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
O que você precisa
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 2, imagem 1 %32
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 3, imagem 1 %32
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, imagem 1 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, imagem 2 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, imagem 3 %32
    • Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • On the bottom of the laptop, find the bottom-plate screw holes. They are located near the disc drive. Parallel to them is a 2.4mm screw.
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew.
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 6, imagem 1 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Flip the laptop over and open it facing you.
    • Use a spudger to lift the bottom black cover on both sides.
    • The cover is connected to an aluminum strip, so be careful lifting it.
    • For the proceeding steps, put on an anti-static wrist strap and clip it to something metal. Ensure that it's clipped to a grounded metal in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, imagem 1 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, imagem 2 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, imagem 3 %32
    • Once the black cover is lifted, flip it and set it on the keyboard.
    • Locate the hardware disc on the right side and gently lift it out. Place it on the side of the laptop.
    • The hard drive is connected with a strip, so be careful when lifting it out.
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, imagem 1 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, imagem 2 %32 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, imagem 3 %32
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and use a spudger, preferably a wider one, to remove the black pin holder on the side where it touches the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until the holder comes off.
Conclusão
3 outras pessoas executaram este guia.
Nicholas Ross
Membro desde: 01/20/12
186 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-31, Amido Winter 2012 Membro de Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
Membros da 5
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 5,325
