Ir para o conteúdo principal
Fujifilm XP20 LCD Screen Replacement
O que você precisa
  1. Fujifilm XP20 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
    • Using a Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm XP20 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 2, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement: passo 2, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm XP20 LCD Screen Replacement: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm XP20 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 4, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement: passo 4, imagem 3 %32
    • Using a 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm XP20 LCD Screen Replacement: passo 5, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 5, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement: passo 5, imagem 3 %32
    • Unlatch the four clasps located on each side of the camera by hand.
    • The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm XP20 Battery Replacement for instructions.
  6. Fujifilm XP20 LCD Screen Replacement: passo 6, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 6, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement: passo 6, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
  7. Fujifilm XP20 LCD Screen Replacement: passo 7, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 7, imagem 2 %32 Fujifilm XP20 LCD Screen Replacement: passo 7, imagem 3 %32
    • Take the spudger and wedge it in between the screen and the frame.
    • Slowly make your way around the screen with the spudger just enough to separate the screen from the frame.
  8. Fujifilm XP20 LCD Screen Replacement: passo 8, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 8, imagem 2 %32
    • Take the spudger again and wedge it in the thinner frame to pry the LCD screen from the frame.
    • Make your way around with the spudger just enough to separate the screen and frame once again.
  9. Fujifilm XP20 LCD Screen Replacement: passo 9, imagem 1 %32 Fujifilm XP20 LCD Screen Replacement: passo 9, imagem 2 %32
    • Take the spudger and wedge it very carefully between the LCD screen and the very thin and fragile frame.
    • Very carefully make your way around the frame with the spudger, while making sure not to use too much force. Otherwise the screen will be damaged.
  10. Fujifilm XP20 LCD Screen Replacement: passo 10, imagem 1 %32
    • Detach the LCD screen from the motherboard by detaching the orange ribbon.
Conclusão
Stephen Harden
Membro desde: 10/08/16
243 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-1, Wilson Fall 2016 Membro de IUPUI, Team 1-1, Wilson Fall 2016
IUPUI-WILSON-F16S1G1
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 1,222
