Introdução
This guide shows how to replace a Fujifilm X30 lens that may be cracked or damaged.
Ferramentas
Peças
Nenhum componente especificado.
Turn the camera upside down.
Place your thumb on the switch, and slide it towards the center of the camera.
Begin by removing the outside screws using a Phillips #000 Screwdriver:
Remove the three 3.6 mm silver screws located on the bottom of the camera.
Remove all four of the 4.7 mm screws from the sides of the camera.
4 outras pessoas concluíram este guia.
