Introdução
This guide will show you how to replace the lens assembly on the Fujifilm X-M1.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
O que você precisa
Turn the camera upside down to locate the battery compartment.
Slide the button up to open the compartment.
Slide the orange button up to release the battery.
Twist the lens cap to remove it from the camera.
Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
Use tweezers to remove the top metal ring and the thin metal ring below it .
