Ir para o conteúdo principal
Fujifilm X-M1 LCD Screen Replacement
O que você precisa
  1. Fujifilm X-M1 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: passo 2, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: passo 2, imagem 2 %32 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Twist the lens cap to remove it from the camera.
    • Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
  3. Fujifilm X-M1 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the four 4.3 mm Phillips screws inside the lens assembly.
  4. Fujifilm X-M1 LCD Screen Replacement, Back Case: passo 4, imagem 1 %32
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  5. Fujifilm X-M1 LCD Screen Replacement: passo 5, imagem 1 %32
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  6. Fujifilm X-M1 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  7. Fujifilm X-M1 LCD Screen Replacement: passo 7, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 7, imagem 2 %32
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  8. Fujifilm X-M1 LCD Screen Replacement: passo 8, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 8, imagem 2 %32 Fujifilm X-M1 LCD Screen Replacement: passo 8, imagem 3 %32
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  9. Fujifilm X-M1 LCD Screen Replacement: passo 9, imagem 1 %32
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  10. Fujifilm X-M1 LCD Screen Replacement: passo 10, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 10, imagem 2 %32
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  11. Fujifilm X-M1 LCD Screen Replacement: passo 11, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 11, imagem 2 %32 Fujifilm X-M1 LCD Screen Replacement: passo 11, imagem 3 %32
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  12. Fujifilm X-M1 LCD Screen Replacement: passo 12, imagem 1 %32
    • Slide the frame around the LCD to remove it from the camera.
  13. Fujifilm X-M1 LCD Screen Replacement: passo 13, imagem 1 %32
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  14. Fujifilm X-M1 LCD Screen Replacement: passo 14, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 14, imagem 2 %32
    • Use tweezers to unhook the speaker near the left handgrip.
  15. Fujifilm X-M1 LCD Screen Replacement: passo 15, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 15, imagem 2 %32
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  16. Fujifilm X-M1 LCD Screen Replacement: passo 16, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 16, imagem 2 %32 Fujifilm X-M1 LCD Screen Replacement: passo 16, imagem 3 %32
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
  17. Fujifilm X-M1 LCD Screen Replacement, LCD Screen: passo 17, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement, LCD Screen: passo 17, imagem 2 %32
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
  18. Fujifilm X-M1 LCD Screen Replacement: passo 18, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 18, imagem 2 %32
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
  19. Fujifilm X-M1 LCD Screen Replacement: passo 19, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 19, imagem 2 %32
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
  20. Fujifilm X-M1 LCD Screen Replacement: passo 20, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 20, imagem 2 %32
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
  21. Fujifilm X-M1 LCD Screen Replacement: passo 21, imagem 1 %32 Fujifilm X-M1 LCD Screen Replacement: passo 21, imagem 2 %32 Fujifilm X-M1 LCD Screen Replacement: passo 21, imagem 3 %32
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
  22. Fujifilm X-M1 LCD Screen Replacement: passo 22, imagem 1 %32
    • Remove the LCD from the screen cover.
Conclusão
Uma outra pessoa concluiu este guia.
Kelsea Weber
Membro desde: 11/12/15
21.027 Reputação
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 59
Ao todo: 5,697
