Ir para o conteúdo principal
Fujifilm X-M1 Back Case Replacement
O que você precisa
  1. Fujifilm X-M1 Back Case Replacement, Battery: passo 1, imagem 1 %32 Fujifilm X-M1 Back Case Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 Back Case Replacement, Back Case: passo 2, imagem 1 %32
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  3. Fujifilm X-M1 Back Case Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  4. Fujifilm X-M1 Back Case Replacement: passo 4, imagem 1 %32
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  5. Fujifilm X-M1 Back Case Replacement: passo 5, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 5, imagem 2 %32
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  6. Fujifilm X-M1 Back Case Replacement: passo 6, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 6, imagem 2 %32 Fujifilm X-M1 Back Case Replacement: passo 6, imagem 3 %32
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  7. Fujifilm X-M1 Back Case Replacement: passo 7, imagem 1 %32
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  8. Fujifilm X-M1 Back Case Replacement: passo 8, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 8, imagem 2 %32
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  9. Fujifilm X-M1 Back Case Replacement: passo 9, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 9, imagem 2 %32 Fujifilm X-M1 Back Case Replacement: passo 9, imagem 3 %32
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  10. Fujifilm X-M1 Back Case Replacement: passo 10, imagem 1 %32
    • Slide the frame around the LCD to remove it from the camera.
  11. Fujifilm X-M1 Back Case Replacement: passo 11, imagem 1 %32
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  12. Fujifilm X-M1 Back Case Replacement: passo 12, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 12, imagem 2 %32
    • Use tweezers to unhook the speaker near the left handgrip.
  13. Fujifilm X-M1 Back Case Replacement: passo 13, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 13, imagem 2 %32
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  14. Fujifilm X-M1 Back Case Replacement: passo 14, imagem 1 %32 Fujifilm X-M1 Back Case Replacement: passo 14, imagem 2 %32 Fujifilm X-M1 Back Case Replacement: passo 14, imagem 3 %32
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
Conclusão
Kelsea Weber
Membro desde: 11/12/15
20.600 Reputação
Autoria de 32 guias
Equipe
iFixit, Team S1-G1, Weber Summer 2018 Membro de iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Membros
Autoria de 43 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 1,574
