Ir para o conteúdo principal
Fujifilm Instax Minion Motor Replacement
O que você precisa
  1. Fujifilm Instax Minion Motor Replacement, Camera Shell: passo 1, imagem 1 %32 Fujifilm Instax Minion Motor Replacement, Camera Shell: passo 1, imagem 2 %32 Fujifilm Instax Minion Motor Replacement, Camera Shell: passo 1, imagem 3 %32
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Motor Replacement: passo 2, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 2, imagem 2 %32 Fujifilm Instax Minion Motor Replacement: passo 2, imagem 3 %32
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Motor Replacement: passo 3, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 3, imagem 2 %32 Fujifilm Instax Minion Motor Replacement: passo 3, imagem 3 %32
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Motor Replacement: passo 4, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 4, imagem 2 %32 Fujifilm Instax Minion Motor Replacement: passo 4, imagem 3 %32
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Motor Replacement: passo 5, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 5, imagem 2 %32 Fujifilm Instax Minion Motor Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Motor Replacement: passo 6, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 6, imagem 2 %32 Fujifilm Instax Minion Motor Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Motor Replacement, Motor: passo 7, imagem 1 %32 Fujifilm Instax Minion Motor Replacement, Motor: passo 7, imagem 2 %32
    • Remove the four 4.5 mm #00 Phillips screws on the battery compartment.
  8. Fujifilm Instax Minion Motor Replacement: passo 8, imagem 1 %32
    • Lift up the battery compartment to free up the motor.
  9. Fujifilm Instax Minion Motor Replacement: passo 9, imagem 1 %32
    • Unscrew the two 2.9mm Phillips #00 screws holding the motor to the frame.
  10. Fujifilm Instax Minion Motor Replacement: passo 10, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 10, imagem 2 %32
    • Remove the motor from the frame.
  11. Fujifilm Instax Minion Motor Replacement: passo 11, imagem 1 %32 Fujifilm Instax Minion Motor Replacement: passo 11, imagem 2 %32
    • Desolder the wires from the leads of the capacitor.
    • Take note of the connections between the wires and leads for reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Jeffery
Membro desde: 03/28/15
220 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G6, Livingston Spring 2018 Membro de Cal Poly, Team S18-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G6
Membros da 4
Autoria de 11 guias
Um comentário
Can anyone help finding a motor for the instax 8 or 9? I can't find one to fit any help appreciated
Jordan Kelly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 1,402
