Ir para o conteúdo principal
Fujifilm Instax Minion Lens Bellow Replacement
O que você precisa
  1. Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: passo 1, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: passo 1, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: passo 1, imagem 3 %32
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Lens Bellow Replacement: passo 2, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 2, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 2, imagem 3 %32
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Lens Bellow Replacement: passo 3, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 3, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 3, imagem 3 %32
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Lens Bellow Replacement: passo 4, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 4, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 4, imagem 3 %32
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Lens Bellow Replacement: passo 5, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 5, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Lens Bellow Replacement: passo 6, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 6, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 6, imagem 3 %32
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: passo 7, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: passo 7, imagem 2 %32
    • Once the shell is off, remove the two 4.5 mm screws from the circuit board using a Phillips #00 screwdriver.
  8. Fujifilm Instax Minion Lens Bellow Replacement: passo 8, imagem 1 %32
    • Once the circuit board is off and to the side, remove the four 4.5 mm screws that are around the front lens case using a Phillips #00 screwdriver.
  9. Fujifilm Instax Minion Lens Bellow Replacement: passo 9, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 9, imagem 2 %32
    • Turn the camera onto its back and remove the four 4.5 mm screws attaching the lens bellow to the case using a Phillips #00 screwdriver.
    • The lens must be extended in order to have access to the screws.
    • Remove the rectangular screw casing from the back of the camera.
  10. Fujifilm Instax Minion Lens Bellow Replacement: passo 10, imagem 1 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 10, imagem 2 %32 Fujifilm Instax Minion Lens Bellow Replacement: passo 10, imagem 3 %32
    • Flip the camera over to its front side again and remove the lens casing by lifting it up and off the camera.
    • Finally, remove the lens bellow by lifting it up and off the camera.
Conclusão
Jonnah Lee
Membro desde: 04/18/18
473 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G6, Livingston Spring 2018 Membro de Cal Poly, Team S18-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 520
