Introdução
This is a simple replacement. There are many steps and components, but the most important tool you will need is a Phillips #00 screwdriver.
O que você precisa
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Once the shell is off, remove the two 4.5 mm screws from the circuit board using a Phillips #00 screwdriver.
Quase terminado!
Conclusão
