Introdução
Take caution as to not touch both ends of the capacitor, or any exposed ends of wire that are connected to such. The capacitor stores a large amount of charge, and could shock you. You will need a soldering station and something to remove old solder, such as a desoldering pump or a solder wick.
O que você precisa
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Remove the four 4.5 mm screws inside the battery holder with a long #00 Phillips screwdriver.
