Ir para o conteúdo principal
Fujifilm Instax Minion Camera Shell Replacement
O que você precisa
  1. Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: passo 1, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: passo 1, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: passo 1, imagem 3 %32
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Camera Shell Replacement: passo 2, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 2, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 2, imagem 3 %32
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Camera Shell Replacement: passo 3, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 3, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 3, imagem 3 %32
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Camera Shell Replacement: passo 4, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 4, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 4, imagem 3 %32
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Camera Shell Replacement: passo 5, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 5, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Camera Shell Replacement: passo 6, imagem 1 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 6, imagem 2 %32 Fujifilm Instax Minion Camera Shell Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
Conclusão
Jonnah Lee
Membro desde: 04/18/18
473 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G6, Livingston Spring 2018 Membro de Cal Poly, Team S18-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G6
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 2,053
