Introdução
This replacement is fairly straight forward. The only tool you will need is a #00 Phillips screwdriver and/or an extra long #00 Phillips screwdriver. Optionally, you could use a nylon spudger to help pry open the camera shell.
O que você precisa
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
