Ir para o conteúdo principal
Fujifilm Instax Mini 8 Lens Unit Replacement
O que você precisa
  1. Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: passo 1, imagem 1 %32 Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: passo 1, imagem 2 %32 Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: passo 1, imagem 3 %32
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Lens Unit Replacement: passo 2, imagem 1 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 2, imagem 2 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 2, imagem 3 %32
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera.
    • Once all screws are removed, gently pry open the front casing carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  3. Fujifilm Instax Mini 8 Lens Unit Replacement: passo 3, imagem 1 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 3, imagem 2 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 3, imagem 3 %32
    • Locate the four screws on the lens unit by the corners and remove them to loosen the lens casing from the main frame. Make sure to keep hold of the unit screws to use for the next step.
  4. Fujifilm Instax Mini 8 Lens Unit Replacement: passo 4, imagem 1 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 4, imagem 2 %32 Fujifilm Instax Mini 8 Lens Unit Replacement: passo 4, imagem 3 %32
    • Remove the lens unit from the main camera frame.
    • Obtain the replacement part to perform the replacement operation.
Conclusão
8 outras pessoas executaram este guia.
Bo W
Membro desde: 10/02/12
1.025 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-1, Meier Fall 2015 Membro de USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Membros
Autoria de 26 guias
13Comentários do guia
the lens covers on my lens broke (the small black pieces that cover the lenses) and i am unable to put back on, will this affect my camera and pictures because of the ex poser?
marisabellares - Responder Compartilhar
When I dropped my instax mini 8, none of the lense pieces broke, they just fell apart, I just need to puzzle them back together. Can you make a tutorial to put the yellow and black parts in the lense back together?
Julia Tyler - Responder Compartilhar
My daughter dropped her camera and the round, hard plastic part that goes over the lens fell out along with a black piece that has four prongs. There is also a spring attached at a section that would look like 4-5 o'clock if looking at the camera head on. I am not sure where the other end of spring attaches to. Please help
Mike Rutledge - Responder Compartilhar
I too am having the same problem as the people in the posts above. Is there a solution somewhere? Thanks
Toby Gilling - Responder Compartilhar
I followed this tutorial but when I initally took the case apart a small rectangular piece fell out and I'm not sure where it should go. The piece has a hole which is set to one side, and a slight groove and arch. I can't see the piece on any of the tutorials. Can anyone help? Thanks
Nicola Jaye - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 40
Últimos 30 dias: 248
Ao todo: 74,365
