Introdução
Is the button to take a photo on your Fujifilm Finepix S1800 jammed or broken? This guide will show you step by step on how to replace the jammed or broken button.
O que você precisa
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
