Ir para o conteúdo principal
Fujifilm Finepix S1800 Back Cover Assembly Replacement
O que você precisa
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: passo 1, imagem 1 %32
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 2, imagem 1 %32
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 3, imagem 1 %32
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 4, imagem 1 %32 Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 4, imagem 2 %32
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Rockford
Membro desde: 02/15/17
618 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 8-6, Eyestone Spring 2017 Membro de USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 403
