Introdução
Use caution when carrying through with procedure, there are components involved than can pinch you when taking it apart.
O que você precisa
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Using the metal spudger, place it in between the leather grip and the black plastic compartment
Quase terminado!
Conclusão
