Introdução
Use caution when going through with the procedure. This procedure involves doing operations near the motherboard of the device, which has many sensitive components.
O que você precisa
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Use a plastic opening tool to lift up the right side of the display screen.
Uma outra pessoa concluiu este guia.
Um comentário
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
