Ir para o conteúdo principal
Fujifilm Finepix S1000fd Display Screen Replacement
O que você precisa
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: passo 1, imagem 1 %32 Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: passo 1, imagem 2 %32
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: passo 2, imagem 1 %32 Fujifilm Finepix S1000fd Display Screen Replacement: passo 2, imagem 2 %32
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: passo 3, imagem 1 %32
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: passo 4, imagem 1 %32
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: passo 5, imagem 1 %32
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: passo 6, imagem 1 %32
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: passo 7, imagem 1 %32
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: passo 8, imagem 1 %32
    • Lift up the gray component where the display screen use to sit in.
Conclusão
Uma outra pessoa concluiu este guia.
Lizzie Eller
Membro desde: 01/25/17
422 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-7, Banghart Winter 2017 Membro de Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
Membros da 4
Autoria de 10 guias
Um comentário
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 913
