Ir para o conteúdo principal
Fujifilm Finepix F10 6.3 MP Lens Replacement
O que você precisa
  1. Fujifilm Finepix F10 6.3 MP Lens Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 2, imagem 1 %32
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 3, imagem 1 %32
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 4, imagem 1 %32 Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 4, imagem 2 %32 Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 4, imagem 3 %32
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Replacement, Front cover: passo 5, imagem 1 %32
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 6, imagem 1 %32
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 7, imagem 1 %32 Fujifilm Finepix F10 6.3 MP Lens Replacement: passo 7, imagem 2 %32
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: passo 8, imagem 1 %32 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: passo 8, imagem 2 %32 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: passo 8, imagem 3 %32
    • Firmly grasp the lens and pull completely from housing.
Conclusão
Sarah Looper
Membro desde: 03/11/13
100 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 13-4, Benson Spring 2013 Membro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
Membros da 2
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 1,727
