Ir para o conteúdo principal
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
O que você precisa
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 2, imagem 1 %32
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 3, imagem 1 %32
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, imagem 1 %32 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, imagem 2 %32 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, imagem 3 %32
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: passo 5, imagem 1 %32 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: passo 5, imagem 2 %32
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 6, imagem 1 %32
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 7, imagem 1 %32
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Looper
Membro desde: 03/11/13
100 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 13-4, Benson Spring 2013 Membro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
Membros da 2
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 808
