Ir para o conteúdo principal
Fujifilm Finepix F10 6.3 MP LCD Replacement
O que você precisa
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 2, imagem 1 %32
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 3, imagem 1 %32
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, imagem 1 %32 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, imagem 2 %32 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, imagem 3 %32
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: passo 5, imagem 1 %32
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 6, imagem 1 %32
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 7, imagem 1 %32 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 7, imagem 2 %32
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Looper
Membro desde: 03/11/13
100 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 13-4, Benson Spring 2013 Membro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
Membros da 2
Autoria de 16 guias
3 comentários
Great Guide! Worked great to replace my screen!
Daniel - Responder
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Responder
Shutter button replacement was great too!
Daniel -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 20
Duração total: 979
