Introdução
This guide will explain how to remove the back cover from the camera. This is the cover that is around the LCD side of the camera. Simply removing the screws and pulling apart the casing are the only steps necessary.
  1. Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
      • Three 5.4 mm tri-head screws.
  2. Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
      • Two 3.3 mm Phillips #00 screws.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  5. Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
Conclusão
2 outras pessoas concluíram este guia.
Johnston Thayer
28 reputação
Autoria de 1 guia
Equipe
Clemson, Team 13-4, Benson Spring 2013 Membro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membros
8 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 485
