Ir para o conteúdo principal
Fujifilm FinePix Z5 Motherboard Replacement
O que você precisa
  1. Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Motherboard Replacement: passo 2, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Motherboard Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 3, imagem 2 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the back of the camera by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Motherboard Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 4, imagem 2 %32
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Motherboard Replacement: passo 5, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Motherboard Replacement: passo 6, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 6, imagem 2 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold ribbon cable which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw on the right side which is anchoring the motherboard.
  7. Fujifilm FinePix Z5 Motherboard Replacement: passo 7, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 7, imagem 2 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 7, imagem 3 %32
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Motherboard Replacement: passo 8, imagem 1 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 8, imagem 2 %32 Fujifilm FinePix Z5 Motherboard Replacement: passo 8, imagem 3 %32
    • Hold wires on the left with an index finger.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Lauren Gibbs
Membro desde: 02/10/12
1 Reputação
Autoria de 1 guia
Equipe
James Madison, Team 3-4, Klein Spring 2012 Membro de James Madison, Team 3-4, Klein Spring 2012
JMU-KLEIN-S12S3G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 717
