Pular para o conteúdo principal
Introdução
The battery access door for the Fujifilm FinePix Z1 is attached with a spring and a rod that allows for easy opening and closing of the door. If the screw is damaged or has somehow been jammed, the door may not open or close correctly. This guide will aid you in fixing the malfunctioning pieces.
Ferramentas
Peças
Nenhum componente especificado.
  1. Locate the Battery Access Door on the bottom of the camera.
    • Locate the Battery Access Door on the bottom of the camera.
    • Ensure that the door has no obvious cracks or damage.
    • See if the door slides out and opens completely.
  2. Apply pressure to the door and pop the component out. Using a H0.7 bit, push the rod out of the door to remove it from the camera. Adjust or replace the spring.
    • Apply pressure to the door and pop the component out.
    • Using a H0.7 bit, push the rod out of the door to remove it from the camera.
    • Adjust or replace the spring.
Conclusão
Carra
Membro desde: 30-01-2018
533 reputação
4 Guias de autoria
Equipe
Baylor, Team S2-G4, Johnson Spring 2018 Membro de Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Membros
4 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 48
