Introdução
Use this guide to replace a broken or malfunctioning lens on your Fujifilm FinePix XP80 camera.
O que você precisa
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Using the H1.3 hex head bit, remove the four screws on the front of the camera.
Using a plastic opening tool, remove the entire lens housing.
Install the new lens and housing (it is replaced as a single unit).
