Ir para o conteúdo principal
Fujifilm FinePix XP80 Lens Replacement
O que você precisa
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, imagem 1 %32 Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, imagem 2 %32 Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, imagem 3 %32
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: passo 2, imagem 1 %32
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: passo 3, imagem 1 %32
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: passo 4, imagem 1 %32
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: passo 5, imagem 1 %32
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: passo 6, imagem 1 %32
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: passo 7, imagem 1 %32
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: passo 8, imagem 1 %32
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: passo 9, imagem 1 %32 Fujifilm FinePix XP80 Lens Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: passo 10, imagem 1 %32
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: passo 11, imagem 1 %32
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: passo 12, imagem 1 %32
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: passo 13, imagem 1 %32 Fujifilm FinePix XP80 Lens Replacement: passo 13, imagem 2 %32 Fujifilm FinePix XP80 Lens Replacement: passo 13, imagem 3 %32
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: passo 14, imagem 1 %32
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: passo 15, imagem 1 %32
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
Conclusão
Amanda Lewis
Membro desde: 09/25/16
317 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Cagle Fall 2016 Membro de USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,503
