Introdução
Learn how to remove the interior Fujifilm FinePix XP80 housing.
O que você precisa
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Using the H1.3 hex head bit, remove the four screws on the front of the camera.
Quase terminado!
Conclusão
