Ir para o conteúdo principal
Fujifilm FinePix XP70 Front and Back Panel Replacement
O que você precisa
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: passo 1, imagem 1 %32
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 2, imagem 1 %32 Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 2, imagem 2 %32
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 3, imagem 1 %32
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: passo 4, imagem 1 %32
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 5, imagem 1 %32
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 6, imagem 1 %32
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 7, imagem 1 %32
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 8, imagem 1 %32 Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 8, imagem 2 %32
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 9, imagem 1 %32
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 10, imagem 1 %32 Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 10, imagem 2 %32 Fujifilm FinePix XP70 Front and Back Panel Replacement: passo 10, imagem 3 %32
    • Pry the back plate off with a plastic opening tool
Conclusão
Olivia A
Membro desde: 10/24/16
484 Reputação
Autoria de 4 guias
Equipe
Um comentário
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Ao todo: 439
