Ir para o conteúdo principal
Fujifilm FinePix XP70 Button Replacement
O que você precisa
  1. Fujifilm FinePix XP70 Button Replacement, Battery: passo 1, imagem 1 %32
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Button Replacement: passo 2, imagem 1 %32 Fujifilm FinePix XP70 Button Replacement: passo 2, imagem 2 %32
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Button Replacement: passo 3, imagem 1 %32
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Button Replacement, Button: passo 4, imagem 1 %32 Fujifilm FinePix XP70 Button Replacement, Button: passo 4, imagem 2 %32
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Button Replacement: passo 5, imagem 1 %32
    • Pull the three buttons out.
Conclusão
Olivia A
Membro desde: 10/24/16
484 Reputação
Autoria de 4 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 320
