Ir para o conteúdo principal
Fujifilm FinePix XP50 LCD Screen Replacement
O que você precisa
  1. Fujifilm FinePix XP50 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP50 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 2, imagem 2 %32
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP50 LCD Screen Replacement: passo 3, imagem 1 %32
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP50 LCD Screen Replacement, Button: passo 4, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement, Button: passo 4, imagem 2 %32
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP50 LCD Screen Replacement: passo 5, imagem 1 %32
    • Pull the three buttons out.
  6. Fujifilm FinePix XP50 LCD Screen Replacement, Front and Back Panel: passo 6, imagem 1 %32
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP50 LCD Screen Replacement: passo 7, imagem 1 %32
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP50 LCD Screen Replacement: passo 8, imagem 1 %32
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP50 LCD Screen Replacement: passo 9, imagem 1 %32
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP50 LCD Screen Replacement: passo 10, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 10, imagem 2 %32
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP50 LCD Screen Replacement: passo 11, imagem 1 %32
    • Lift off the front plate.
  12. Fujifilm FinePix XP50 LCD Screen Replacement: passo 12, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 12, imagem 2 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 12, imagem 3 %32
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP50 LCD Screen Replacement, Back Panel: passo 13, imagem 1 %32
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP50 LCD Screen Replacement: passo 14, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 14, imagem 2 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 14, imagem 3 %32
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP50 LCD Screen Replacement: passo 15, imagem 1 %32
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP50 LCD Screen Replacement: passo 16, imagem 1 %32 Fujifilm FinePix XP50 LCD Screen Replacement: passo 16, imagem 2 %32
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP50 LCD Screen Replacement, LCD Screen: passo 17, imagem 1 %32
    • Use the plastic opening tool to gently lift the LCD screen up.
Conclusão
Cory Teixeira
Membro desde: 03/24/17
101 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 516
