O que você precisa
Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
Use a T5 Torx bit to secure the exterior decorative cover of the device.
Locate the securing tabs of the housing unit.
Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
*** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
Locate the ribbon cable attachment for the rear panel controls.
Gently lift the ribbon cable securing bar and slide the ribbon cable from the socket in order to remove the rear control panel.
