Ir para o conteúdo principal
Fujifilm FinePix T500 LCD Screen Replacement
O que você precisa
  1. Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix T500 LCD Screen Replacement: passo 2, imagem 2 %32 Fujifilm FinePix T500 LCD Screen Replacement: passo 2, imagem 3 %32
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 LCD Screen Replacement: passo 3, imagem 1 %32 Fujifilm FinePix T500 LCD Screen Replacement: passo 3, imagem 2 %32
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm FinePix T500 LCD Screen Replacement: passo 4, imagem 2 %32 Fujifilm FinePix T500 LCD Screen Replacement: passo 4, imagem 3 %32
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
Conclusão
George Lindner
Membro desde: 01/20/15
252 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 19-3, Blackwell Winter 2015 Membro de USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 6
Ao todo: 684
