Introdução
This is a guide for replacing the screen on the Fujifilm FinePix S9500 camera. The screen is a digital display that allows the user to adjust settings, and view pictures on the memory card. This guide will show you how to remove the case top, and the back case of the camera to access the screen for the purposes of replacement.
O que você precisa
Locate and remove two screws. They are M1.7 x 5.0 in size.
The first screw is below and to the left of the command dial on the back of the camera.
The second screw is on the right side of the camera, to the right of the strap mount.
To open the case, gently push upward in the area just below the command dial with your thumb.
To release the catch located on the left of the command dial and at the base of the flash, place your thumb to the right of the command dial and push upwards at a 45° angle towards the flash.
There are four screws on the right side of the camera that need to be removed.
To the left of the AE-L dial, there is a brace that needs to be removed. Take out the screw from that panel.
Remove the white LCD FPC from the camera back and the orange LCD FPC from the main body to separate the camera. Start by gently pulling the white LCD FPC away from the back of the camera, then remove the orange LCD FPC from the main body of the camera.
Remove the two M1.7 x 2.5 Phillips screws located on the left and right sides of the orange LCD FPC.
Remove the display assembly.
Uma outra pessoa concluiu este guia.
