Ir para o conteúdo principal
Fujifilm FinePix S8630 Flash Lid Spring Replacement
O que você precisa
  1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: passo 1, imagem 1 %32
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 2, imagem 1 %32
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 3, imagem 1 %32
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 4, imagem 1 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 4, imagem 2 %32
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 5, imagem 1 %32
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, imagem 2 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, imagem 2 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, imagem 3 %32
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: passo 8, imagem 1 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: passo 8, imagem 2 %32
    • Firmly grasp the flash bulb lid and remove the lid from the camera.
  9. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, imagem 1 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, imagem 2 %32 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the spring and grasp with the tweezers.
    • Pinch and compress the spring to remove it from the camera housing.
    • Slide the lever that was holding the spring out of the camera housing.
Conclusão
Equipe
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro de USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 353
