Ir para o conteúdo principal
Fujifilm FinePix S8200 Selector Replacement
O que você precisa
  1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: passo 1, imagem 1 %32
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Selector  Replacement: passo 2, imagem 1 %32
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Selector  Replacement: passo 3, imagem 1 %32
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: passo 4, imagem 1 %32 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: passo 4, imagem 2 %32 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: passo 4, imagem 3 %32
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Selector  Replacement: passo 5, imagem 1 %32 Fujifilm FinePix S8200 Selector  Replacement: passo 5, imagem 2 %32 Fujifilm FinePix S8200 Selector  Replacement: passo 5, imagem 3 %32
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Selector  Replacement: passo 6, imagem 1 %32
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: passo 7, imagem 1 %32
    • To Replace the Selection button, carefully pull the button until the button has been fully detached.
Conclusão
Uma outra pessoa concluiu este guia.
Ugent Dailey
Membro desde: 01/20/15
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-1, Remmell Winter 2015 Membro de USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Membros
Autoria de 9 guias
Um comentário
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 12
Ao todo: 1,195
