Introdução
It happens to best of us. Your device hits the floor and now the case is damaged. Don't panic, because all you need are a screwdriver and a tool to remove the plastic case and you can replace this component very easily.
O que você precisa
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
4 outras pessoas executaram este guia.
4 comentários
hey, can you show how to remove the lense from this camera, please!!
hey, can you please show how to remove the lens from this camera. thanks
Thank you for your guide, exactly what i was looking for.
Jordan, web dev at Casinos Hunter Fr
Very interesting and useful guide my friend. Really if you could show us how to remove the lenses on this camera model, it would be just super!
Greetings from Oliver Garcia
Content Master and Graphic Quality Control at CasinoLandia
