Ir para o conteúdo principal
Fujifilm FinePix S4800 Battery Compartment Door Replacement
O que você precisa
  1. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 2, imagem 1 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 2, imagem 2 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 2, imagem 3 %32
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 4, imagem 1 %32
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 5, imagem 1 %32
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 6, imagem 2 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 6, imagem 3 %32
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 7, imagem 2 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 8, imagem 1 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement: passo 8, imagem 2 %32
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: passo 9, imagem 1 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: passo 9, imagem 2 %32 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: passo 9, imagem 3 %32
    • Once the rear case is removed, gently separate the battery compartment door from its position.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S19-G4, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 30
Duração total: 2,638
