Introdução
To replace the viewfinder you will need to perform the LCD prerequisite. The viewfinder should be replaced if your camera does not focus or your photos lack composition.
O que você precisa
Turn the camera off.
Turn the camera upside down so that the battery compartment is showing.
Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
