Ir para o conteúdo principal
Fujifilm FinePix S4200 LCD Screen Replacement
O que você precisa
  1. Fujifilm FinePix S4200 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 LCD Screen Replacement: passo 3, imagem 1 %32
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 LCD Screen Replacement: passo 4, imagem 1 %32
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 LCD Screen Replacement: passo 5, imagem 1 %32 Fujifilm FinePix S4200 LCD Screen Replacement: passo 5, imagem 2 %32 Fujifilm FinePix S4200 LCD Screen Replacement: passo 5, imagem 3 %32
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 LCD Screen Replacement: passo 8, imagem 1 %32 Fujifilm FinePix S4200 LCD Screen Replacement: passo 8, imagem 2 %32
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 LCD Screen Replacement: passo 9, imagem 1 %32
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 LCD Screen Replacement: passo 10, imagem 1 %32
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 LCD Screen Replacement: passo 11, imagem 1 %32 Fujifilm FinePix S4200 LCD Screen Replacement: passo 11, imagem 2 %32
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Jackie Acevedo
Membro desde: 09/14/15
340 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 1-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Membros
Autoria de 7 guias
Um comentário
Ou peut on trouver cet écran ?
lise.didion - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 16
Ao todo: 1,674
