Ir para o conteúdo principal
Fujifilm FinePix S2980 Speaker Replacement
O que você precisa
  1. Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: passo 1, imagem 2 %32 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: passo 1, imagem 3 %32
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Speaker Replacement: passo 2, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 2, imagem 2 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 2, imagem 3 %32
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Speaker Replacement, Speaker: passo 3, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement, Speaker: passo 3, imagem 2 %32 Fujifilm FinePix S2980 Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Speaker Replacement: passo 4, imagem 1 %32
    • Use the opening tool to pry the top plate off of the top of the camera.
  5. Fujifilm FinePix S2980 Speaker Replacement: passo 5, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 5, imagem 2 %32
    • Remove the four larger silver plated screws placed on the inside of the lens.
    • Remove the lens by lifting it up from the cavity.
  6. Fujifilm FinePix S2980 Speaker Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 6, imagem 2 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 6, imagem 3 %32
    • Remove the five bracket screws.
  7. Fujifilm FinePix S2980 Speaker Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S2980 Speaker Replacement: passo 7, imagem 2 %32
    • Once the screws are out, remove the the bracket
    • Remove speaker with given tweezer tool and replace
Conclusão
diane heidke
Membro desde: 03/24/15
24 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 15
Ao todo: 1,114
