Ir para o conteúdo principal
Fujifilm FinePix HS30EXR Lens Replacement
O que você precisa
  1. Fujifilm FinePix HS30EXR Lens Replacement, Frame: passo 1, imagem 1 %32
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Lens Replacement: passo 2, imagem 1 %32
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Lens Replacement: passo 3, imagem 1 %32
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Lens Replacement: passo 4, imagem 1 %32
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Lens Replacement: passo 5, imagem 1 %32
  6. Fujifilm FinePix HS30EXR Lens Replacement: passo 6, imagem 1 %32
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Lens Replacement: passo 7, imagem 1 %32 Fujifilm FinePix HS30EXR Lens Replacement: passo 7, imagem 2 %32
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Lens Replacement, Motherboard: passo 8, imagem 1 %32
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Lens Replacement: passo 9, imagem 1 %32
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Lens Replacement: passo 10, imagem 1 %32
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Lens Replacement: passo 11, imagem 1 %32
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Lens Replacement: passo 12, imagem 1 %32
  13. Fujifilm FinePix HS30EXR Lens Replacement: passo 13, imagem 1 %32
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Lens Replacement: passo 14, imagem 1 %32
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Lens Replacement: passo 15, imagem 1 %32
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Lens Replacement, Lens: passo 16, imagem 1 %32
    • Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
    • Take the lens off once it is unscrewed.
  17. Fujifilm FinePix HS30EXR Lens Replacement: passo 17, imagem 1 %32
    • Un-attatch the current lens, and replace it with the new lens.
Conclusão
3 outras pessoas executaram este guia.
Andrew Scouten
Membro desde: 10/22/18
838 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S1-G2, Williams Fall 2018 Membro de Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
Membros da 4
Autoria de 12 guias
Um comentário
What is the price for Normal lens for Fujifilm HS30EXR?
khadgarai286 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 73
Duração total: 4,533
