Introdução
This guide serves as a tear-down of the frame and is meant to be used with the intention of removing it. This action is needed to access the inside components.
Warning: The frame may be damaged in this process, as well as the ribbon cable that connects the motherboard with the LCD Screen. Be very careful with the removal of the frame to avoid any damage.
O que você precisa
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
