Ir para o conteúdo principal
Fujifilm FinePix HS30EXR Frame Replacement
O que você precisa
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: passo 1, imagem 1 %32
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: passo 2, imagem 1 %32
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: passo 3, imagem 1 %32
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: passo 4, imagem 1 %32
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: passo 5, imagem 1 %32
  6. Fujifilm FinePix HS30EXR Frame Replacement: passo 6, imagem 1 %32
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: passo 7, imagem 1 %32 Fujifilm FinePix HS30EXR Frame Replacement: passo 7, imagem 2 %32
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
Conclusão
Andrew Scouten
Membro desde: 10/22/18
838 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S1-G2, Williams Fall 2018 Membro de Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 693
