Introdução
This guide will show you how to replace the Mode Dial on the camera if it has stopped working or if it is stuck and will not move.
O que você precisa
Hold the camera with the lens facing towards youself.
Turn the camera upside down and place your right thumb on the battery chamber cover.
Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
Hold the camera like you are going to take a picture, and the top bar should be able to separate from the camera a little bit.
With the tweezers remove the ribbon cable from its clip to completely separate the top bar from the camera.
