Ir para o conteúdo principal
Fujifilm FinePix F505EXR Battery Replacement
O que você precisa
  1. Fujifilm FinePix F505EXR Battery Replacement, Battery: passo 1, imagem 1 %32 Fujifilm FinePix F505EXR Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Battery Replacement: passo 2, imagem 1 %32 Fujifilm FinePix F505EXR Battery Replacement: passo 2, imagem 2 %32
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Battery Replacement: passo 3, imagem 1 %32 Fujifilm FinePix F505EXR Battery Replacement: passo 3, imagem 2 %32
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
Conclusão
Matthew Kilmonis
Membro desde: 03/08/17
219 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 1,207
