Ir para o conteúdo principal
Fujifilm FinePix AX665 Lens Housing Replacement
O que você precisa
  1. Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, imagem 1 %32 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, imagem 2 %32 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, imagem 3 %32
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, imagem 1 %32 Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, imagem 2 %32 Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, imagem 3 %32
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Lens Housing Replacement: passo 3, imagem 1 %32 Fujifilm FinePix AX665 Lens Housing Replacement: passo 3, imagem 2 %32
    • Remove the ribbon cable from the side of the logic board.
  4. Fujifilm FinePix AX665 Lens Housing Replacement: passo 4, imagem 1 %32 Fujifilm FinePix AX665 Lens Housing Replacement: passo 4, imagem 2 %32
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Housing Replacement: passo 5, imagem 1 %32 Fujifilm FinePix AX665 Lens Housing Replacement: passo 5, imagem 2 %32
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Housing Replacement: passo 6, imagem 1 %32
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Housing Replacement: passo 7, imagem 1 %32
    • Remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Housing Replacement: passo 8, imagem 1 %32
    • Remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Housing Replacement: passo 9, imagem 1 %32
    • Remove the lens housing by moving the gray clip holding the unit.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 380
