Ir para o conteúdo principal
Fujifilm FinePix A350 Battery Contact Replacement
O que você precisa
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, imagem 1 %32 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, imagem 2 %32 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, imagem 3 %32
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, imagem 1 %32 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, imagem 2 %32 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, imagem 3 %32
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Conclusão
Jaxon Cramer
Membro desde: 03/21/16
1.045 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 6-4, Benson Spring 2016 Membro de Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
Membros da 4
Autoria de 17 guias
Um comentário
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 461
