Ir para o conteúdo principal
Fujifilm FinePix 4700 Zoom Back Cover Replacement
O que você precisa
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 2, imagem 1 %32
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 3, imagem 1 %32 Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 3, imagem 2 %32 Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 3, imagem 3 %32
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 4, imagem 1 %32 Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 4, imagem 2 %32
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: passo 5, imagem 1 %32
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
Conclusão
Sarthak Patel
Membro desde: 04/03/12
10 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-8, Forte Spring 2012 Membro de Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
Membros da 5
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,191
