Introdução
This guide will instruct camera owners how to take off the outer casing and how to access the red, rubber power button. Once you access the button, you can remove it and replace the button with a new one.
O que você precisa
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Look on the inside of the black back casing.
Locate the red, rubber power button.
Using the tweezers, grab the red, rubber power button and pull it off the casing.
Discard the faulty power button.
Grab the new power button with the tweezers.
Put the power button into place by placing it where the old button was.
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
